Generate sinus via USB 6001
I'd like to generate a sinus with a usb 6001.
I've found this example but I can't get it to work!
Do you know what causes the problem?
thanks in advance.
(2,896 Views)
Ho kooxy,
when you enable Autostart at DAQmxWrite you don't need to call DAQmxStartTask later on…
Did you read the error explanation?
(2,893 Views)
I've just deleted the DAQmxStartTask and the error don't  show up but the generation still dont work.
(2,881 Views)
Please give the task the time to generate your sine before stopping.
(2,875 Views)
Accepted by topic author kooxy
Hi kooxy,
there is a DAQmxWaitUntilDone function - use it!
(2,872 Views)
It works perfectly !
Thank you very much
Solution :
(2,869 Views)
