11-20-2018 03:47 AM
You don't need the constructor. Drop a property node, right click, select CLASS / .NET then browse to System.Windows.Forms, then select SCREEN.
0xDEAD
03-01-2023 10:09 AM
Found this old thread today, looking for the topic. Just wanted to add that on my Windows 10 installation I cannot select any class and "Screen" isn't available at all.
Plus, none of the classes is accepted for the .NET property node because the OK remains locked.
03-01-2023 11:04 AM
You need to double click the System.Windows.Forms line so the + turns into a - and shows you the selections underneath it:
03-02-2023 09:04 AM
Years after this .NET process, AQ and Darren posted a G implementation that works pretty well over on LAVA.
I later turned that into some code that could center a window on the monitor your mouse is on, or center a window under your monitor, but stay within the monitor bounds.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
