HPGL plotting of a legacy Agilent Spectrum Analyzer: Labview
Hi all,
  We have some issues trying to plot a legacy Agilent Spectrum Analyzer.
Currently we are plotting based on reading the trace points. However there are some
constraints that we are currently facing..
  I understand that there is a command to retrieve the HPGL data from the Spectrum Analyzer.
(PLOT?;)
I have extracted the data and placed in plot2.plt (need to rename from txt to plt). I am able to generate the data to the graph through plottergeist.
However I need to integrate with Labview and I need to store the results in JPG rather than PDF.
Is there any VI that can convert the plot2.plt to a X-Y chart?
I have attached a legacy library file which is able to plot up till the grid only.
(2,963 Views)
Try the links in this post.
Note that your data is fairly simple HPGL, so you should be able to write a specific parser for it fairly easily if the above links do not work.  Let us know if you run into trouble.
(2,944 Views)
