11-22-2011 05:56 PM
I thought it better to search the whole range +/-. This will make his VI more flexible rather than fixing it to a specific range.
11-23-2011 04:27 AM
I don't know for what elements will I look for. Range 1-9 was just example. All I know about numbers is that they are integers from 0 to 2000 or more.
So I think good way to handle that is to find Max and min value in array and then search and increment by 1
11-23-2011 06:51 AM
Were you able to open my .zip file? This should work per your spec. The only thing I forgot to include was the position of the element in the array, but with some modifications you should be able to do that. You did not mention Max/Min in your ealier posts, but Max/Min should not matter, at least it doesn't with my VI. It will simply return the single instances found in a 2D array.
11-23-2011 09:13 AM - edited 11-23-2011 09:14 AM
How big is the input array going to be? Greater than 2000?
It might be better to increment through a 1D copy of the input array check each index to the rest of the array for matches.
Than to check for all possible values (2000+)
