Help Converting Traditional NiDaq Counter VIs to NidaqMX
I am looking for support on getting the attached VI converted to NiDaq MX. Any help or guidance would be much appreciated.  I have attached VI and all associated with its hierarchy incase it was required.  VI I am looking for help on is named "Read Digital 1/min Raw Data"
Current version is labview 7 moving to LabVIEW 2017
Thanks in advance for any help / guidance.
(2,312 Views)
Have you checked that document : http://www.ni.com/tutorial/4342/en/ ?
CLAMaxime -- Kudos are a great way to say thank you
(2,307 Views)
You might also find my Traditional DAQ API useful.  You can just copy the VIs into your LabVIEW 2017\vi.lib and then you can open everything in LabVIEW 2017 and see exactly which DAQ calls were being done and get an idea of what you will have to do with DAQmx.
GCentral
(2,284 Views)
