Help Saving and recalling a TDS Waveform from a file.
I have tried everything I can find in the examples with no luck.
I have a Waveform that I have acquired on my TDS 360. I have it ouput to a graph on the VI front panel.
That works great.
The Graphed waveform is exactly what I need.
Now all I want to do is save this to a file and be able to recall it later on another graph.
I have to do 10 acquistions in a row and store each one as a serperate file.
I want to be able to recall them one by one to a graph for analysis.
Please does anyone have an VI I can copy.
Smiley Sad
(2,812 Views)
Hi rcard53762,
Have you taken a look at our Write to Measurement File Express VI and Read from Measurement File Express VI?  These VI's will bring up a configuration dialog box when you place them on the block diagram that walks you through setting up your file I/O.  If you do not want to use these, you can also take a look at the Write-Read Text File.vi in the NI Example Finder.  This example shows different methods of writing and reading from file.  To get to this example, open LabVIEW » Help » Find Examples » Fundamentals » File Input and Ouput » Write-Read Text File.vi.
Please let me know if you have any further questions.  Best of luck on your application!!
Ching P.
DAQ and Academic Hardware R&D
(2,797 Views)
This is what I get when I wire the TDS Graph to the File Write Express.
See Attachment.
(2,794 Views)
Try this. The Tek Read Waveform returns a cluster that the waveform graph can accept but the Write Measurement File expects either a signal data type or a waveform data type. The code below will convert the cluster to a waveform data type.
Message Edited by Dennis Knutson on 02-27-2007 10:59 AM
(2,792 Views)
Thanks for the help that worked.
(2,775 Views)
