Help for conditional indexing in LV 2012?
Not that I need it, but I could not find any help on the new LV 2012 Conditional Indexing feature. It appears in the contextual menu, but the contextual help does not provide any hint of what this is, and it's nowhere to be found in the Help:
Message 1 of 21
(3,624 Views)
One thing I still want to do is bench mark this. I'm assuming it is using in placeness in the background, but I still want to make sure, just haven't had a chance yet. Has anyone benchmarked it yet, or can anyone from NI comment on this?
Message 2 of 21
(3,613 Views)
Accepted by topic author X.
You can find the help section here, although it's pretty slim - https://www.ni.com/docs/en-US/bundle/labview/page/conditionally-writing-values-to-loop-output-tunnel...
I can say that the performance was tested during the beta and that the performance is the same as using Build Array in a case structure. I'm assuming NI will change this to have better performance, but I don't know when.
___________________
Try to take over the world!
Message 3 of 21
(3,601 Views)
It looks like they may have already. I am not getting poor performance when benchmarking in the 2012 release right now.
Message 4 of 21
(3,588 Views)
I'll have to do some digging to make sure, but I beleive the for loops were fine performance wise because LabVIEW can pre-allocate the maximum size.  The while loops behaved the same as the build array (or was it even worse?).  Like I said, I'll have to do some digging in the beta forum.
GCentral
Message 5 of 21
(3,585 Views)
I just wrote my own benchmarking code and it seemed to work fine with the for loops. I would expect the while loops to have to use whatever algorithm build array uses when it grows, due to not knowing the max size of the array before hand so this makes sense. What I can't figure out is why my preallocate, replace array subset, trim off the "fat" method is still slower than the conditional autoindexing. What could they be doing differently in the background that would enhance this performance?
Message 6 of 21
(3,582 Views)
Care to share your benchmarking code?  From what I was digging up, the conditional terminal should behave EXACTLY like the Build Array method.
For anybody that cares, there is a CAR 342504 to document the performance "issues" we found.
GCentral
Message 7 of 21
(3,577 Views)
Let me know if I made a mistake. 7 a.m. is pretty early for me!
Message 8 of 21
(3,567 Views)
Sorry it took so long to get back.  I had to download LV2012.  I think I still need to download the patch.  And also setup all of my setting and addons.  VIPM will be busy for the rest of the day.
Anyways, your benchmark is flawed.  Add outputs to the arrays and you will get radically different results.  I think some of your loops didn't exactly iterate the 10000 times since there was no output.  And I have no clue what you were trying to show with the second benchmark.
I didn't edit the labels yet.  So for those who haven't looked at the VI, "x/y" is the time for pre-allocating and keeping only what is needed.  "x/y 2" is the same except with another data type.  "x/y 3" is using the build array.  "x/y 4" is using the new conditional indexing feature.  Each one is looped 10000 times and the average is given (in ms).
GCentral
Message 9 of 21
(3,541 Views)
Doh, I just assumed you didn't need the output, but that makes sense if LabVIEW sees it is unused it may optimize. Thanks for looking over that. The second benchmark was just showing in placeness for that scenario when I sent it out to my coworkers also in case some were unfamiliar. Had no real value for this benchmarking
Message 10 of 21
(3,532 Views)
