Help $$$$$ how to find distance between points
Hello My Friends
Could you please help me to write such a program in Matlab or other software able to find the distance from 1,1 to 3,3 .
[COLOR="#FF0000"]Note: all the points are real on the map an has ( longitude) and ( latitude ).
[/COLOR]
regards
(3,263 Views)
Pythagorean Theorem
They're teaching this to you in school, right?
(3,257 Views)
Distance between all points is 3?
The answer must be 3! Smiley Very Happy
Now is the right time to use %^<%Y-%m-%dT%H:%M:%S%3uZ>T
If you don't hate time zones, you're not a real programmer.
"You are what you don't automate"
Inplaceness is synonymous with insidiousness
(3,246 Views)
Why the heck did you put $$$$ in the title?
(3,233 Views)
The accepted solution gets $$$$ from a Nigerian prince. You pay only shipping and handling. 😄
(3,223 Views)
This is not a matlab forum. An example for "other" software is LabVIEW. Do you have it installed?
This can be an extremely difficult question.
Since this is on a real map, are the distanced large enough that you need to consider the curvature of the earth? Do you want the shortest path along the surface or are you allowed to dig underground? Do you need to account for mountains?
(3,215 Views)
 I sincerely doubt that this is anything more than a homework question, especially given the way it was asked. But, assuming it's not (and even if it is)... http://www.movable-type.co.uk/scripts/latlong.html
All that trig.
(3,178 Views)
