05-17-2017 02:31 PM
Is it possible to insert a PDF into an Excel worksheet using Active X in LabVIEW? Has anyone done this before? For example, I want to prompt the user to select a PDF file and then have LabVIEW automatically insert that PDF into Excel.
05-17-2017 02:57 PM
If you have the Report Generation Toolkit, there is a VI called Excel Insert Object. Should do what you are asking even though I haven't tried it to verify.
