How can I fix the appearance of graph cursors?
I have a front panel which has some XY graphs on it, and I need to have the cursor legend displayed.
That works just fine, but the pesky cursor arrows that appear on the front panel have, through a process that I don't understand, become visually mangled.  I can't figure what I have to click on to modify their appearance or reset the cursor arrows to their default appearance.
Can anyone tell me how to do that?
Replacing the graph with a new one is a last resort - I could do that, but then I would have to setup all the graph properties again, and I have multiple graphs that all have this problem.
Screenshots attached to post.
-ron
(2,434 Views)
ron,
What version of LV are you using?
Is it possible to cross test this with another PC?
Norbert
Norbert
Expert: Geometry
(2,411 Views)
Norbert,
LV 2011, SP1.
This is actually a chronic and pandemic problem that I've ignored for a long time - so its present across multiple LV versions (going back to LV8.x) and this occurs on every PC that I install the program on.
(2,401 Views)
Can you post a VI which shows this behavior?
Does a new graph show this by default? If not, what did you do that it happened?
Does it only occur in VIs you updated from older LV versions?
thanks,
Norbert
Norbert
Expert: Geometry
(2,363 Views)
I've attached a VI in which I've pasted one of the mangled graphs from my application, and also created a brand new graph.  The new one has un-mangled cursors.
Just to clarify, the cause of the problem is clear - at some point in my development, I started playing with the placement of the cursors by hovering the mouse cursor over them and then stretching and moving them.  However, I found them very difficult to mold and shape as a I wanted and just ended up with a mangled mess.  I'm hoping that I can find a way to "undo" all of those changes, by re-setting the apperance of the cursors.
This isn't a "bug" where Labview is incapable of creating non-mangled graph cursors.
Thanks!
(2,350 Views)
Hm, possibly not a "solution" but better than having reprogramming parts of the software using property nodes:
You can replace the indicator by right click>>replace. Select the appropriate default graph (e.g. XY Graph). It will reset the graphical shape to a default XY Graph, but leave all code untouched.
Alternativly (if you had to reshape several instances of that graph) you can define a "strict type definition" derived from the original LV graph. Save it. Use it as replacement as described above.
A strict type def defines all properties of a control except the data value. So all instances will look alike and visual properties can only be altered in the type def itself.
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,345 Views)
Norbert,
Thanks for the suggestions.  The "replace" option is certainly better than deleting the graph and starting from scratch.
It's not ideal, and this is exactly what I was afraid of, but at least now I know that I'm not wasting my time by reseting all of the graphs manually.
(2,339 Views)
