01-14-2019 07:31 AM
it's 2019
Screens and graphics allow a more easy way (better readability) to display long numbers (on each side of the decimal seperator).
Numeric inputs and outputs of a modern UI should be able to group the numbers with fractions of a space (I would prefer as a general seperator).
And don't miss the scales !!
Ideas to push:
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Visual-Aides-Numeric-Separators/idc-p/3881749
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Digit-grouping-for-Numerics/idc-p/2123338
01-14-2019 08:30 AM
There's some good function in .net for this that I made a test with. I can't find it quickly though.
/Y
01-14-2019 10:45 AM - edited 01-14-2019 10:46 AM
Well. since 20 years I can use TeX to set nice tables for documents ... however, I want this in native LabVIEW on my UI including the graph scales.
01-14-2019 11:57 AM
@Henrik_Volkers wrote:
it's 2019
"long numbers" (especially with a reasonably number of significant digits), should probably be displayed in SI or scientific format anyway. Much more concise.
Even with seperators, things will get out of hand if you need to (mis?)count the number of triplets, for example. The problem is just pushed a little bit, but still exists.
01-15-2019 03:23 AM
There's a good .net function for that, that I finally figured out (though I agree with Altenbach about the SI format).
/Y
01-15-2019 06:00 AM
@altenbach wrote:"long numbers" (especially with a reasonably number of significant digits), should probably be displayed in SI or scientific format anyway. Much more concise.
That is why my go to formats for numbers is "%0.3p" and "%#.3p" (depending on if I really want to see the trailing 0s or not).
01-15-2019 08:22 AM
Unless you have to deal with ppms and ppbs 😉
01-15-2019 09:01 AM - edited 01-15-2019 09:01 AM
That would be an exception. 99.5% of the time, 3 decimal places is more than enough.
01-15-2019 09:35 AM - edited 01-15-2019 09:36 AM
Say for 99,5% of the applications ...
unless you work in a national metrology lab... 😄
05-30-2024 08:42 AM
There was a small bug with code posted above. You to exclude a comma when the "substring after match" output = "" (null string) otherwise it adds an extra comma at the beginning of the number.
