11-01-2009 08:46 AM
Hello
I am trying to shift an image which has been saved as .png with vision infos. This image I would like to shift by x/y pixels. If I do so I get a
blank image back, even I copied all the image infos in advance.
If I am using any other image without vision infos it works without problem so far. Does anybody knows how I can solve this problem?
Thanks in advance
Solved! Go to Solution.
11-02-2009 12:25 PM
11-04-2009 04:48 AM
Hi Alex
I attached again the .vi and an example image.
Norick
11-04-2009 10:12 AM
11-07-2009 07:43 AM
That's it..!
Thank you
