How can i give digital input to servo via only LabVIEW?
I have a test rig that contains a servo motor and 2 photomultipliers. I use a NI DAQ card to give analog input to servo and to take output from photomultipliers. I have constructed VI programme. Everything works and i can perform my experiments. But, the servo rotates very slowly even if i stop it from LabVIEW VI interface. I think there is a noise due to my cabling between servo and DAQ card. This situation affects the experiment results. So, i want to cancel out the DAQ card in only motor control. I want to try to make a connection between PC and servo via RS232 and give digital input to servo with using only LabVIEW. At this time, i will still use the DAQ card to collect output from my photomultipliers. Is this solution possible and how can i control my servo using only LabVIEW? Thank you all.
(2,685 Views)
Read the manual for the servo controller and see what it says about how to communicate with it.  Often there is an interface, and very likely it uses ModBUS.
(2,661 Views)
I have to admit I do not really understand your question but... The servos I have worked with had a "trim" adjust on them that had to be set or you would see the exact behaviour you are seeing.
Send a "stop" command and adjust the trimmer until the servo remains stationary.
=== Engineer Ambiguously ===
(2,646 Views)
