How can i hide( close or exit) the windows media player window from front panel after a video is played.
I want a video to be played when i star executing a vi. After that i want to remove(hide or close) the media player window from my front panel.how can i do this?
the vi is attached.
Electronics and Instrumentation Engineer
Freelance LabVIEW and Arduino programmer.
For projects contact me ; djac791@gmail.com
(3,026 Views)
Accepted by topic author djacob
Check out the attached code.
If it solves your problem then dont forget to mark this as a solution. Also if you like the answer dont forget to give me kudos 🙂
Tushar Jambhekar
tushar@jambhekar.com
Jambhekar Automation Solutions
LabVIEW Consultancy, LabVIEW Training
Rent a LabVIEW Developer, My Blog
(3,020 Views)
thank u so much ,this is exactly what i needed.
i need one more help.can you please check this post http://forums.ni.com/t5/LabVIEW/How-to-use-status-pins-4-outputs-and-data-pins-8-inputs-of-the/m-p/1...
(3,016 Views)
