How can we tell if a VI is already running before calling Start Asynchronous Call?
Being quite an old thread, the importance has nevertheless not changed, nor has the state of solutions. I found something rather weird, but ingenious at the same time. Check it out:
Find truly executing VIs by trying to save the run-time menu
KUDOs to Tanja Troescher.
Message 11 of 14
(1,207 Views)
 I think this could also be a solution for your problem.
Message 12 of 14
(632 Views)
comrade's "Find truly executing VIs by trying to save the run-time menu" is nice if the code will only run in LabVIEW (especially since you can output to a nul device "\\.\NUL" to avoid actual disk access) but that property is not available at run-time.
Message 13 of 14
(495 Views)
Sushant_Kumar, the problem with your solution is that it will output Running even when it is just Waiting to Run (i.e., when its caller is running but it is not).
Message 14 of 14
(491 Views)
