06-12-2014 10:44 AM
The problem that I have is not that I can read power factor because our RTU gives me a analog input in numeric fomat for our power factor. I need to know if there is some sort of scaling or indicator ( such as a analog dial type gauge) that can be scaled to read power factor in the below format. We want to see Lag / Lead that mimics our mechanical analog meter at the power plant. Any suggestions?
-0.5
-0.6
-0.7
-0.8
-0.9
1.0
0.9
0.8
0.7
0.6
0.5
06-12-2014 10:53 AM
Why not just use the dial or guage in the Numeric Controls palette? You can change the scales easily enough to be a -1 to +1.
06-12-2014 10:54 AM
You can certainly use a gage or meter to display the values that you state. What specifically is your problem? How often do you get a new value?
Mike...
11-20-2015 12:22 PM
I have exactly the same problem. How to do it? If you create a scale with a minimum and a maximum value of -0.5 + 0.5, in the center of the scale is 0 instead of 1 as it should be...
11-20-2015 12:42 PM
11-20-2015 12:47 PM
I think he wants to make a LabVIEW version of the real-life meter seen here:
http://www.alibaba.com/product-detail/BE-96-96-96-Power-Factor_1707875502/showimage.html
I don't know how you'd do that with any sort of standard control, though...
11-20-2015 12:57 PM
11-20-2015 03:08 PM
It should look something like this. I used a text label for scale markers.
text labes Value
-0.5 0
-0.6 1
-0.7 2
-0.8 3
-0.9 4
1 5
0.9 6
0.8 7
0.7 8
0.6 9
0.5 10
But how to convert 1 +/- 0.5 -->> 0 to 10 I don't know...
11-20-2015 03:42 PM
Solved. Thanks to everyone
