How do I get a running sum of elements in an array?
i.e Array1 = 2,3,5,1,4 -> Array2 = 5,10,11,15
(3,101 Views)
I am confused as to what you want to sum...
do you want to sum 2,3,5,1,4 etc...
or do you want to sum 2,5 3,10 5,11 etc... ???
Dan
(3,101 Views)
I want to have a running sum of an array, for example, that is 2,3,5,1,4 and get an array with that running sum 5,10,11,15.
(3,101 Views)
You can use e.g. the code of the attached image.
(3,101 Views)
Small Correction: I did not notice that you apparently don't want the first element, and the result should be smaller by one. In this case, simply clip the first element from the output (e.g. as shown in the image using array subset starting at element 1).
(3,101 Views)
Perfect, Thank you.
(3,101 Views)
