How do I use TestStand to trigger an event in LabView VI?
I have a VI with an event structure. An event is triggered when either Button 1 or Button 2 is pressed. How do I program NI TestStand to trigger the same event in the VI?
(1,005 Views)
Accepted by topic author KCLL
You can use Value (Signaling) Property to fire an event programmatically. However, you should be careful in using a VI with a while loop as a code module in TestStand. The step might be stuck at the VI with the while loop unless you run that VI asynchronously. Asynchronously Starting and Stopping a VI in TestStand
Control Lead | Intelline Inc
(988 Views)
Thanks ZYOng!  That works.
(926 Views)
