How do i make a cursor in my graph?
How do i create a vertical cursor that is movable? I really need some help with that! I need the cursor to be able to move and read the readings from my graph. Can anyone teach me? thanx! Here is my vi!
(2,960 Views)
Right click on graph > visible items > Cursor legend.
Then you can create cursors.
Bijay
(2,955 Views)
I have tried but when i run the program, there isnt any cursor moving. Why is that so? Here is my vi.
(2,953 Views)
Accepted by topic author GG_Jialat
As Vijay said and you already implemented. In your graph cursor is there but if you see carefully your cursor x/y value is out of x/y scale range.
Do one thing just right click on your cursor under cursor pallet and select bring to center or go to cursor option.
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
(2,947 Views)
Thanx for the solution! It works! 🙂
(2,940 Views)
Mark the post as solution if issue is solved. Smiley Happy
Bijay
(2,934 Views)
