How to Connect SbRIO to Host using NEtwork Stream
I am using a program to transfer data from the PC to the Starter Kit using NEtwork Streams.Can anybody tell me how the IP of the PC / SbRIo should be configured in order to connect successfully.
(2,760 Views)
Hey,
The first thing to do is make sure that the sbRIO can been seen in MAX under Remote Systems.  There is lots of info on the web for connecting cRIO which will be the same for a sbRIO.  Try these:
Install NI LabVIEW, LabVIEW Real-Time and FPGA Modules, and NI-RIO Driver
Assemble Your NI CompactRIO System
Configure Your NI CompactRIO System for First Use
Configure NI CompactRIO for DHCP
Configure NI CompactRIO With a Static IP Address
Install Software on Your NI CompactRIO Controller
Introduction to NI LabVIEW
Lewis Gear CLA
LabVIEW UAV
(2,737 Views)
