How to Programmatically Pair and Unpair a bluetooth device?
Hi all,
I have a Bluetooth modem, which i want to programmatically Pair & Unpair. Using the available VIs, i could able to search the services and when i try to connect to the device using one service, windows pops-up the dialog to enter the Passkey (during that time, the VI gives an error out). I want to know, how to programmatially pair the device, meaning how to programmatically enter the passkey, so that user doesnot need to do anything using windows.
logic
(5,354 Views)
Bluetooth pairing is not supported in LabVIEW. This is mentioned in this forum as well Does labview support bluetooth
If you fill out a product suggestion at the Product Suggest Center then R&D will see that it is a desired feature and will take that into consideration.
Nick R
NI
(5,325 Views)
Here is a vi that lets you pair with a bluetooth device. You need the 32feet in the hand .net package
http://32feet.net/files/
-Regards
eximo
_______________________________________________
UofL Bioengineering M.S.
Neuronetrix
"I had rather be right than be president" -Henry Clay
(4,388 Views)
