How to access value from inside while loop outside of the loop
for the first suggestion, I cannot  dequeue the whole 1D Array because I enqued it one by one.(And if I enqueue it as array I will get a cluster of arrays which will be hard to deal with).
For the second one I tried but cant get it to work yet.
the third one seems good, except how do I access the counter in the consumer loop? this is my main problem.
the counter in the producer loop is the output of a sub vi, and it goes froom 0-50 and resets.
If I just use a shift register in the consumrt and increment it each time it will not reset when it reaches 50 and keeps increasing.
Thanks!!
Message 11 of 12
(565 Views)
Work with Single Element Queue.
Just Reshape your Array to desired dimensions. Where is the difficult here?
Assuming if ur array will "Not Stop"  after build 2D Array process. Here's simple counter logic with Shift Register: Eternal loop between 0 and 50.
Message 12 of 12
(554 Views)
