How to add control or indicator at runtime?
@yoppy wrote:
Thank you Fragger Fox abundantly.. I wonder how I can set and get values from the created controls.For example, I type on String control, and I want to catch the value on the string control.
If you use that approach you would have to use the VI Server to open references to the VIs and use the VI Server method Get Control Value and Set Control Value.
Message 11 of 11
(373 Views)
