How to change a specific bit to 0 or 1?
In general, I would really recommend to stick with a solution that does not use any thick green wires (Dave's solution above is better! :)). Bit manipulations should be done with blue wires. Going the detour via boolean arrays is easily an order of magnitude slower and requires an order of magnitude more memory.
For some illustrations, have a look at the results of the old bit twiddling challenge: http://zone.ni.com/devzone/cda/tut/p/id/5307
Message Edited by altenbach on 05-06-2008 07:08 AM
Message 11 of 30
(3,537 Views)
Altenbach,
you are, in general, correct about the performance issues. I just made a small benchmark with my solution and dave's. dave's is about 6 times faster than mine.
But now there is one thing i am wondering:
My solution depends on the actual "length" of the number; the higher the value, the longer the vi takes for 1,000,000 iterations. The time does increase about 10% (950 ms up to about 1100). BUT: It does not have to much impact how many bits i mask.
dave's solution does only mask one bit at an iteration, so i think, if masking more bits, the time used to solve this will increase in reference to the number of bits. A single bitmask took (for 1,000,000 iterations) 170 ms on my machine. So if the increase for "bits to mask" is additive, my solution would be equal to dave's @ about 6 bits.
So, just wondering: is my thinking correct? If it is, is there a more elegant way to solve this?
Please note that the screenshots in the link to the bit twiddling challenge do not enlarge on my system... (i use firefox, but it does not work in IE either.....)
Norbert
Norbert
Expert: Geometry
Message 12 of 30
(3,520 Views)
Hi Norbert,
this is my update...
greets, Dave
Message Edited by daveTW on 05-06-2008 05:54 PM
Greets, Dave
Message 13 of 30
(3,500 Views)
MikeS81 wrote:
Nice solution Norbert,
but what´s that? Smiley Happy
Mike
Message Edited by MikeS81 on 05-06-2008 11:21 AM
Mike,
That's Norbert's version of Rube Goldberg Code. Smiley Very Happy
- Partha ( CLD until Oct 2024 🙂 )
Message 14 of 30
(3,464 Views)
Dave,
that's a very nice, "generic" solution for masking. My first approach was actually very similar, but i missed the part i encircled in blue. That's why i switch to the less performant arrayhandling, which is really not the best as altenbach correctly pointed out....
Norbert
Message Edited by Norbert B on 05-08-2008 02:23 AM
Norbert
Expert: Geometry
Message 15 of 30
(3,393 Views)
Hello. I was told that it is possible also to change specific bit in this way (picture attached). But it doesn't work for me. Can someone help me please? What I want to do is to change specific bit value in the register. Thank you
Message 16 of 30
(1,099 Views)
Hi Lily,
you forgot to attach your code - we cannot debug/edit/run images in LabVIEW!
  • Which way of "change a bit" do you need? Clear, set, negate? Use AND, OR, XOR…
  • Why is there a coercion dot in your image?
  • Which bit do you want to change?
  • Do yo want to change a single bit or more than one bit at once?
Message 17 of 30
(1,089 Views)
for example, I have a register with address xF13 and data there x1111. I want to change bit 4 from 1 to 0. How this can be done ? thank you
Message 18 of 30
(1,079 Views)
Hi Lily,
The register address is irrelevant for the task:
When clearing bits you need to create a "negative" mask, that's what the inverted input does…
Message 19 of 30
(1,072 Views)
Will it also work in a reverse order ? To change 0 to 1 ?
Message 20 of 30
(1,059 Views)
