How to connect Position sensor (Thorlab) to the NI DAQ (6343)?
Working on project where I have to read the position of the light beam using optical position sensor.
I use optical position sensor from thorlabs (PDQ30C) and for the data acquisition I use NI-DAQ(6343).
Now position sensor has 6 pin Hiros connection cable and now I need to connect the position sensor to the DAQ , but do now have idea how to connect and at what port of the DAQ I have to connect.
Position sensor :
https://www.thorlabs.de/newgrouppage9.cfm?objectgroup_id=4400&pn=PDQ30C
Link shows six pin connector  and how each pin gives different signal.
NI-DAQ 6343:
https://www.ni.com/documentation/en/multifunction-io-device/latest/usb-6343/pinout-bnc/
Could any one give me some idea how to make connection between position sensor and DAQ for data acquisition.
Thank you
(3,711 Views)
Looks like you need a +ve power supply line and a -ve power supply line, and then two Analog Input values to measure the X and Y values.
Connect pins 1 and 2 to your Analog Inputs of choice, and 5 to the common (GND) value for both the power supply/ies and DAQ.
Connect 4 and 6 to +- voltages respectively.
For others' reference, the datasheet can be found here: https://www.thorlabs.com/drawings/b9c5691259b472d2-9F6EB426-A265-47DD-59C2F13832EADE1A/PDQ30C-SpecSh...
GCentral
(3,677 Views)
So in short,
I connect 1 and 2 pin to the analog input and 5 to the common.
Can I apply power supply from DAQ by connecting 4 and 6 pin to the one of the analog output port?
(3,533 Views)
In short, no.
The voltage levels on an analog output are suitable but the maximum current is much too low for your sensor.
GCentral
(3,528 Views)
I checked on specification of the DAQ (Analog output ) it shows output current +- 5mA
and limit for the sensor is 35mA
(3,521 Views)
Accepted by topic author mi1111
The DAQ value is a maximum. The sensor value is a requirement. You need at least that much.
You can if you need supply the positive value from the DAQ board via the +5V output, which can source 1A, but you have no negative supply.
GCentral
(3,516 Views)
Hi mi,
That's not a "limit", but a requirement!
Use an external power supply!
(3,515 Views)
