How to disable the specific elements in the enumerator by other enumerator functions
I have three enumerator functions.
If I select the 1st enumerator first element then 2nd enumerator function top two elements should disable.
If I select the 1st enumerator second element then 2nd enumerator function 3rd and 4th elements should disable.
If I select the 1st enumerator third element then 3rd enumerator function top two elements should disable.
thanks.
with regards and warm welcome,
Ramamoorthy S
(2,469 Views)
Hi
i attached a sample vi that shows the concept. you can develop it into the actual logic that you want, with Enum 1, 2 and 3.
post your code if need more help.
Regards
Freelance_LV
TestAutomation Consultant
(2,454 Views)
I new to labview so can you please let me know this
how use the properties node.
usages of properties node.
Ramamoorthy S
(2,445 Views)
Hi
Righ click on a front panel object, go to Create Property Node menu item and refer to the Context Help on each property. Read LabVIEW Help and LabVIEW Basic tutorials for more information.
Regards
Freelance_LV
(2,443 Views)
