How to export XY Graph as PNG?
I am exporting the results of an XY Graph as an image using the Export Image Invoke Node. This method only allows users to export as .bmp, .emf, .eps, and .pict. I want to export a .png, so I worked around this issue by writing the .bmp file, reading its image data, deleting the original .bmp, and replacing it with a .png (using Read BMP File.vi and Write PNG File.vi). If possible, I would like to avoid ever having to write the .bmp, as it is about 15-20x the size and just takes up extra time for a file I am never going to use. Is there a better way to do what I am trying to do?
I have attached my VI in case my process wasn't clear enough (sorry for the mess of wires)!
(1,438 Views)
Accepted by topic author chrisl03
Use invoke node Get Image instead of Export Image.  Then you can use Write PNG File.vi
George Zou
(1,433 Views)
That's perfect. Thanks so much!
(1,425 Views)
Just to add some details, here is a snippet of a VI I keep in my reuse library.  It does use two other VIs from my reuse, but I added notes to state what they do.
GCentral
(1,413 Views)
