How to generate a staircase waveform with the edges SMOOTHENED ?
But since I am using the block as a low pass filter and so I should be specifying only the upper cut off frequency....isn't it?
Message 11 of 12
(561 Views)
Low cut-off is used for lowpass and highpass filters where you only need to specify a single frequency value. High cut-off is ignored.
Both low and high cut-off are used to define bandpass and bandstop filters.
Message 12 of 12
(559 Views)
