How to get LabView 2010 w/DSC module to communicate with EPICS softIOC
Hi All,
As stated in the subject line of this post, I am attempting to display the value of an EPICS process variable (PV) in LabVIEW 2010 (evaluation version).  I have gone throught the steps to create an EPICS Client I/O server, and configuring it by defining an existing PV to access.  I tried creating a bound variable, and configured its shared variable properties as outlined in the documentation.  I dragged the variable from the Project Explorer window into the Front Panel window, and activated continuous run mode, but I get a "Bad quality for: \\my_computer\process_name\variable_name" message.  The remote softIOC & PV value I want to display are working as an Extensible Display Manager (EDM) screen already exists, and correctly shows the value.
The softIOC is running on a Linux host using non-default channel access (CA) ports.  I have defined both user and system environment variables (EPICS_CA_ADDR_LIST, EPICS_CA_REPEATER_PORT & EPICS_CA_SERVER_PORT) on the PC running LabVIEW.  Does the current version of LabVIEW & DSC pay attention to EPICS environment variables?
As others have gotten the same thing as I am attempting operational, I assume that I am making some basic, newbie mistake.  Any light you can shed will be greatly appreciated.
(2,646 Views)
Hi LabVIEW'n'EPICS,
It sounds like you may not have deployed your server.  Can you see it/the PV in Distibuted System Manager (Tools » Distributed System Manager)?  If not, try right clicking the library containing the EPICS Client Server in the Project Explorer and select Deploy.
Drew T.
Camber Ridge, LLC.
(2,631 Views)
