09-18-2019 06:22 AM
1. Stop using infinite loops. The Abort toolbar button is only there for emergencies, not for normal use.
2. Having conditional loops inside of an Event case is a really bad idea. In your case, you won't be able to stop that internal loop because the event case will lock the front panel until it completes. But it won't be able to since it requires pressing the stop button and the button will be locked (unable to click it). Maybe you should use a FOR loop instead for the data generation.
09-18-2019 07:00 AM
I don't see a conditional loop inside the event structure. What I do see is that the stop2 button is generating 2 events - and the second event is locking the front panel. The code can be made to work as is by either making the stop2 button latching (will have to move the button to where the local variable is and use a constant to stop the loop) or by making the event structure not lock the front panel.
I agree with others that this is a poor structure. A state machine would definitely be a better approach.
09-18-2019 07:49 AM
@johntrich1971 wrote:I don't see a conditional loop inside the event structure. What I do see is that the stop2 button is generating 2 events - and the second event is locking the front panel.
I meant a loop with a conditional stop dependent on the GUI. Regardless, "long" processes should generally not be performed inside of an Event Structure. Parallel processing with a Queued Message Handler would be more appropriate in what I think the OP is attempting to do here.
09-18-2019 08:33 AM
@crossrulz
I'm still not sure what you meant here.
I generally use my event structure to handle all GUI events - including the stop. I do agree that the loop within a loop thing is bad form.
I agree. The for loop in the event structure should be its own state in the state machine.
I agree here as well.
09-18-2019 08:45 AM
@crossrulz
I'm still not sure what you meant here..
I'm pretty sure we are at a semantic argument, but in complete agreement on principle. So I will just end it here.
09-18-2019 08:49 AM
I thought so to, but just wanted to make sure there wasn't something that I was missing. I'm always willing to learn from good programmers. 🙂
09-18-2019 09:49 AM - edited 09-18-2019 09:51 AM
@edmonton wrote:State machine uses case structure in a while loop. It seams difficulty to get out of the issue.
None of your attached code resembles a state machine. Her are some tips:
09-18-2019 10:34 AM - edited 09-18-2019 11:08 AM
@altenbach wrote:
You have an outer loop. It can be used for all looping and anchoring of shift registers.
Here's one possible solution. Note that you only need one button for start/stop. See if it makes sense. (It can be further simplified, but start with this).
09-18-2019 10:36 AM
You need to study up more on the state machine. For instance, you could run your generation code ONCE, check to see if the exit condition has been met (this would be the button in your current setup). If the exit condition is met then you would move to the next state. Otherwise you would return to the generation state. With a simple state machine architecture you could likely get rid of your event structure altogether.
You might also study up on Queued Message Handler (QMH) or Queued State Machine.
09-18-2019 11:06 AM
Hi Dr Altenbach and all others who replied my post,
First, thank you all for your inputs.
The data generation loop represents a part of my data acquisition loop. I prefer to use a condition in a for or while loop to manually stop the data generation as a baseline period, the baseline will continue if the baseline is not stable, user can start a measurement by clicking a conditional button to stop the baseline period. I know we can use code to check if the baseline is horizontally smooth, but need a live linear regression to accurately judge the smoothness of the baseline, which is more complicated than a simple manual stop button. The conditional loop has to be in a case structure if a state machine is used. My posted code previously is not a real state machine code, just wanted to show I have to use a conditional loop.
I have a big application VI, and realized that a lot of optimizations can be done if a state machine architecture is used. Currently, I have a very tight schedule to make my project working first. So, I will stay with my original idea at this movement and do optimization using state machine architecture after. Here below is a VI that I have made it work after reading all replies. The only thing is that the stop data selection button (stop2) need to be clicked twice.
Thank you all again.
Gu
