How to manage and clean VIs file organisation in a project without broke dependancies ?
I'm working on a project, on LV 8.5.1 ( but, I can use it with 8.6 ). But, if the item list of my project is clean and easy to read, it is not the case of my file hierarchy. So, I tried to clean myself my VIs hierarchy, with the secret hope that links between VIs will be automaticaly updated 😃 I was wrong, everything was broken :s LV tried to help to find the moved VIs, but it's a very long task ( I've more than 300 VIs in my project)
So, there is an EASY and QUICK way to manage the VI file hierarchy, without have dependencies problem ?
Thanks in advance 🙂
Message Edité par mrjk.78 le 06-18-2009 07:19 AM
(2,168 Views)
In the project window create a "Source Distribution". Once configured and created that source Distribution will pick-up all of the VIs associated with the distribution and provided you chosse "Single prompt preserve hiarchy" it will pick-up copies of everything and save eveything to a new loaction with all of the references updated.
Ben
(2,161 Views)
