How to print picture
I used a program to generate a picture. I want to print it directly with a printer instead of inserting word or ecxcel. What should I do?
Message 1 of 22
(1,657 Views)
Go to windows explorer, right click on the file and select "Print".
Message 2 of 22
(1,634 Views)
If you attached your LabVIEW code, we'd be able to tell what you did to generate the picture.  We'd then (probably) be able to advise you how to export your "picture" (or "image") to as suitable format (like .bmp, .png, .jpeg, etc.) that could be sent to a printer by asking Windows to send the file to the Printer of your choice.
If you are using LabVIEW 2023, please "Save for Previous Version" and specify LabVIEW 2021 or 2019 to get more of the "old-timers" to venture an opinion.
Message 3 of 22
(1,633 Views)
Place your picture on the front panel, then invoke node Print.Panel To Printer:
https://www.ni.com/docs/en-US/bundle/labview/page/lvprop/vi_prnt_pnl_to_prnter.html
This is probably one of the easiest ways.
Message 4 of 22
(1,623 Views)
You can use a function called Read JPEG file then use draw functions to show on the picture indicator, then use the property node described before to print front panel after execution.
Go to VI Properties -> Print
Select the last item.
Message 5 of 22
(1,612 Views)
This is a very generic questions and, (unless you posted in the wrong place!!!), maybe you are actually talking about a LabVIEW program where the picture is displayed on the LabVIEW front panel and you want to use LabVIEW to print this directly.
Assuming this is a LabVIEW question, we can give more specific help once you show us what you have. There are plenty of ways!
Message 6 of 22
(1,602 Views)
Use "System Exec.vi":
mspaint.exe -p imagePath
George Zou
Message 7 of 22
(1,596 Views)
Thank you for your reply, butI want to trigger the printer by clicking a button when the software generates pictures.
Message 8 of 22
(1,592 Views)
please properly describe what you are trying to accomplish.
Message 9 of 22
(1,587 Views)
Again, show us what you have? Do you have a suitable defined default printer?
Message 10 of 22
(1,582 Views)
