How to read time from file onto X axis
Wow it works great! how smart are you... I would have never gotten that all figured out. Thanks a million!!
Message 11 of 13
(802 Views)
Hey sorry to trouble you again, but just noticed the absolute time on the graph starts the data points at 17:00:00 when in fact it's supposed to start at 18:21:34 pm.  I can't figure out where the problem is, it does look like it starts at the right time on the index indicator, it's just the graph that has it off by an hour and 21 minutes.
Message 12 of 13
(759 Views)
What index indicator? What part of the example are you using? The bottom part should be used to get t0. The y values should be gotten by indexing the second column, not the for loop. Show your modified code, please. Also, make sure the graph is not set to ignore timestamps.
Message 13 of 13
(743 Views)
