How to reset a RIO password to the default blank?
How can I reset a NI-9014 cRIO to the default (blank) password the the unit ships with?  I tried in MAX and once a PW is set, is doesn't let you set a blank PW, you must use some text.  This goes along with another recent post of mine (see here) where I need to be able to proove my suspected root cause.  In order to do that, I need to be able to revert back to a blank PW.
More importantly, I should state it like this:  I need to be able to put the RIO in its original state, where the password is not configured (whether that is blank or something else).  Is there a way to do that?
Message 1 of 14
(10,982 Views)
Accepted by topic author AMP12
You can reformat the RIO, which will wipe everything and restore it to a blank state. In Measurement and Automation Explorer, right-click the device and choose Format Disk. You'll then need to reinstall LabVIEW on the RIO, again using MAX.
Message 2 of 14
(10,972 Views)
You can re-format the software and disk space, but not the password if I recall correctly.  I think I already tried that, but I'll doulble check it again in the morning.  I assume the UN and PW is saved to an EPROM or something along those lines.
Message 3 of 14
(10,956 Views)
Nathand, you were correct.  Format disk does return the password to the blank state.  Thanks.
Message 4 of 14
(10,941 Views)
Hi AMP12,
Please follow the steps given in this KB to reset the password to default.
Message 5 of 14
(10,939 Views)
Is the re anybody has the KB or knows how to solve it? The link is apparently broken:
HTTP Web Server: Lotus Notes Exception - Entry not found in index
Zoltan
Message 6 of 14
(10,435 Views)
Can anybody solved that issue? I still cant reset the password on myRio. In the MAX, when I try to format disk, the MAX asks me about actual password.
Message 7 of 14
(9,470 Views)
Are you in safe mode? Try this:
1. Set cRio into safe mode, reboot.
2. Format the cRio, when the tool warns about safe mode choose “Format in Safe Mode” or whatever it says.
3. When finished, turn safe mode off and reboot.
4. Image it normally. It should work this time.
https://www.chiefdelphi.com/t/crio-imaging-tool-hangs-on-rebooting-crio/124910/14
Zoltan
Message 8 of 14
(9,456 Views)
I think so, I hold reset for 5 seconds and the Status Led is blinking 3 times. Am I in Save mode?
Then I try to Format Disk in MAX and the password is again needed. What I'm doing wrong?
Message 9 of 14
(9,437 Views)
You can try one more thing:
1. Hold the RESET button until the STATUS LED turns solid orange or yellow.
2. Release the RESET button and the controller will restart. The STATUS LED will blink three times indicating the controller is in Safe Mode.
3. Hold the RESET button again until the STATUS LED turns solid orange or yellow.
4. Release the RESET button and the controller will reset the password, reset the IP configuration, and restart in Safe Mode.
5. Find the CompactRIO in MAX and restart the controller into Normal Mode.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9dXSAS&l=en-GB
If this does not work, then the easiest would be to contact NI support, as it seems, sometimes it is caused by a corrupt file:
https://forums.ni.com/t5/Real-Time-Measurement-and/Cannot-format-CRIO-9030/td-p/3562620
Zoltan
Message 10 of 14
(9,424 Views)
