How to reset a subVi
@Yamaeda wrote:
@danielepirovano wrote:
The subVi is in a case structure, the subvi starts to run when I change the control of the case structure to true. The subVI runs until I change the control to false.
There are no loops and no shift register in my VI. The "reset signal" is connected to a series of logical controls of the data processor.
Reset the SubVI in the false case. Problem solved. 🙂
/Y
I think you are trying to answer the original thread from 2011, while we are now dicussing something quite different. There is no case structure.
Message 11 of 13
(861 Views)
Hi Altenbach,
Thanks for all your prompt feedback and reply.The VI is poorly designed as it is a compilation of methods that work. Unfortunately I am unable to devote time to optimize my program.
I am currently trying to improve this VI based on your comments, but I am held up by other projects so I may take a while before I can see if the solutions work. But back to my main question, is there a way to clear the uninitialized shift register "other than the add a constant" solution; even quitting the subVI after it returns to caller is acceptable to me. Otherwise, my current solution is to quit the main VI after each run.
Message 12 of 13
(811 Views)
@Oldcreek yes i was. 🙂
A shift register is typically reset by feeding it the reset value from the inside. If you dont have a case structure inside the while loop you can solve it with e.g. a Selector (or depending on structure by indexing out a default/reset value).
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 13 of 13
(792 Views)
