How to save two data from two subdiagram into one file?
I couldn't load your attached vi because some vi's were missing. But what i understand from your messages is that you want to select the path every time you hit the scan button . I have attached a VI which you can take a look. May be it will help you.
Nitzz
(Kudos are always Welcome, Mark as a solution if it is the One;))
Message 11 of 14
(481 Views)
Cool!
This small thing works!
Message 12 of 14
(473 Views)
Hi ANL,
Sorry. Please ignore this post.. Sent by mistake.:)
Nitzz
Message 13 of 14
(459 Views)
Greetings,
I have a related question, but slightly different. What if i want to save two signals in the same file in two different columns but, one of them in scientific format like "%3e" and the other one as a floating number "%2f"?
I am using the "write to spreadsheet file.vi", but if i change the format, it will affect both columns...
The vi is in attachment.
Thanks in advance.
Message 14 of 14
(450 Views)
