How to scan for individual words from a text file?
Well, I have no idea where to start with this. Basically I want to write a program which scans for individual words from a text file. And then depending on what those words are it will execute further functions but for now I just want to figure out the first part: how to scan for individual words from a text file.
I believe I can accomplish this with the Scan From File function, but all the tutorials I find only talk about reading the file and outputting its contents. I want to do something with the contents instead of just outputting them.
(2,862 Views)
What's the format of the file? Reading and outputting the content to an array or string is where you would start.
(2,853 Views)
It is a '.txt' file. This file I have attached is what I have now. This seems to use a case structure and looks for the numeric value stated in the case within the file, then outputs whatever is after that value from the file. Problem is it only looks for numbers and not words. Plus I don't need the stuff after the number. I just need the one word if that makes sense. It's a start.
(2,842 Views)
Saying it is a '.txt' file is just meaningless. If you don't want to explain how the file is formatted or just post a small example, then you will have to work out the details yourself.
(2,837 Views)
It's a .txt, as is made with Windows Notepad. I've attached the actual file I'm using here. Not much, but this is it.
(2,831 Views)
If you are looking for specific words, then you might want to look at the Match Pattern function.
GCentral
(2,825 Views)
Thanks crossrulz and Dennis. I figured out how to use it and Match Pattern is exactly what I needed.
(2,811 Views)
