How to specify source IP address when use LabVIEW SSH tools?
I use PXIe-8522 to communicate with Multiple DUT(use SSH login), but all DUT have a same default IP address, so I can't know which DUT is I connected. then I learned there is a way to specify a source IP address when use SSH, but I couldn't find how to specify in LabVIEW SSH tools.
(209 Views)
LabSSH is a library developed by Labwerx.net. I would recommend you contact them for any inquiries.
From NI-XNET perspective, you can use XNET IP Stack, which allows all Automotive Ethernet to have even same IP address. You can refer to the shipping example Hardware Input and Output >> Automotive Ethernet >> IP Stack >> NI-XNET IP Stack TCP Proxy.lvproj
Control Lead | Intelline Inc
(141 Views)
