09-24-2018 01:24 PM
Hi:
I am working in a German company and currently using LabVIEW program to communicate with laser system. I have some VIs sent by my colleague. However, the context help file is opened in German. I am wondering if there is any way you can easily switch it into English?
Thanks for the help.
Solved! Go to Solution.
09-24-2018 01:53 PM - edited 09-24-2018 01:53 PM
Hi gongchao,
Deinstall German LabVIEW edition, install an English LabVIEW edition.
To avoid any other problems you should install the same version and bitness as is installed right now.
Or use the English online help (like this).
09-24-2018 02:15 PM
Thanks for the reply. Maybe I didn't explain myself clearly. I have installed an English LabView edition. There is no problem for writing and reading VIs in English. But I currently have the packed project library from my German colleague. But after opening the VI, I found the front panel is written in German as well as the context help for the included subVIs. My question is, is there an easy setup that can switch German to English. Thanks
09-24-2018 02:18 PM - edited 09-24-2018 02:18 PM
Hi GongChao,
No, both are "comments", written by the programmer of those VIs/lvlib.
You have to translate them on your own. Or ask your colleague to do that. Or use any translator service on the web you like (and trust)…
09-24-2018 02:20 PM
Understood, thanks a lot.
09-24-2018 02:23 PM
