How to turn a string of two columns intoa numeric array?
I want to turn a string consisting of two columns of numbers to a 2D array so that I can graph the data on an XY graph. How would I do this?
For example, if the string is
1 5
2 4
3 7
4 9
How would I convert this string to a numeric 2D array?
Message 1 of 15
(2,776 Views)
Try "Spreadsheet string to array" and set your delimiter to "Space".
Message 2 of 15
(2,754 Views)
By doing this, my array only returns the first column. I need both values in the first row. There's likely something small I'm missing.
Message 3 of 15
(2,749 Views)
Message 4 of 15
(2,744 Views)
Of course there is, but if you don't show us your code and actual string, we cannot help.
  • Is the type a 2D integer array?
  • Is the delimiter really space or something else (tab, nonprintable, etc.)
  • etc.
Message 5 of 15
(2,742 Views)
No pictures, the actual VI please! We cannot debug pictures!
Also please resize your array containers to show more than one element.
(You delimited looks more like an empty string instead of a space character. LabVIEW will assume tab in that case.)
Message 6 of 15
(2,738 Views)
Is your delimiter (the character between values) actually a space?  Or is it a tab?  Are you sure you even have a space in your delimiter constant?  There is a Space Constant to make it more clear.
GCentral
Message 7 of 15
(2,734 Views)
My apologies. Here are photos of my front panel and block diagram.
Message 8 of 15
(2,733 Views)
Make sure you're expanding the array indicator both vertically AND horizontally.
And post your code, not just pictures (Select All, Edit: Create Snipped from Selection).
Message 9 of 15
(2,731 Views)
Here's the snippet.
Message 10 of 15
(2,728 Views)
