10-05-2017 12:02 PM
hello
I need to communicate programmatically to a printer that was first installed via COM1 RS232 and configured with VISA functions
(document joined, LV2012, sorry for the old bad code)
now it's not working anymore and I would like to use the USB input instead. in the printer properties, the printer is defined as USB006
When I change my VISA initialisation node from COM1 to USB006? if not is there another way?
regards
10-05-2017 04:36 PM
You could try communicating with it using USB RAW mode. However, a lot of devices use different communication over USB than they do serial, so the chances that this will work aren't super great.
10-06-2017 01:09 AM
10-06-2017 07:05 AM
I will try the converter and keep you informed
thanks
