06-16-2011 12:20 AM
Thank very much.
It solved the problem.
I want to add my experience here that the Bluetooth device that you have may be able to install directly without the driver software. Allow it to do so.
Here i want to ask VTKim that how should one resolve a problem if it arrives in a program. Because the discussion forums depends upon the replies of the reader and it's not the quick way of solving your problem.
06-16-2011 04:39 AM
Also what about if i want to work with Zigbee communication protcol.
06-16-2011 05:19 PM
Hi Intelligent,
As far as posting to Discussion Forums, the more information you give in the initial post including what you are using, what you have tested and what your issue is including error numbers, hardware setup, etc makes it a lot easier for everyone to help diagnose your issue. Also, making new posts for new issues is a great way to have better visibility.
As far as Zigbee communication, here are a few tutorials on Zibgee. I hope this helps! Tutorial 1, Tutorial 2.
Kim
06-16-2011 11:17 PM
thanks very much.
