How to write a LabVIEW program with NI 9201 and NI 9481
I need to write a LabVIEW program for automating a pressure scanning system for a supersonic wind tunnel. I have very little programming experience in LabVIEW and in general.
I need to read the voltage from a single pressure transducer for 29 separate pressure taps connected to a Scanivalve. All voltages are read through channel ai0 of NI 9201.
I need to use the NI 9481 relay to step through the channels on the Scanivalve, and each time the relay steps to the next channel, I need the NI 9201 to recognize the new measurement.
During or at the end of the scan, I need to plot the voltage measured at each tap versus the tap number (0, 1, 2, ..., 28).
Ideally, the scanning process would be automated, with 3 seconds between each relay step.
Both the NI 9201 and NI 9481 are in a 4-slot NI cDAQ-9174 chassis.
Thank you very much for any help or support!
(2,923 Views)
Hi Wahoo,
I need to write a LabVIEW program ... Thank you very much for any help
All you wrote between is just the description of your "needs"...
How can we help, when you don't ask specific questions?
- When you want to learn LabVIEW: there are online courses available on www.NI.com.
- You will find a lot of examples in your LabVIEW installation: just look for the "Help" menu...
(2,918 Views)
