01-15-2014 10:52 AM
I finally have the connection working properly.
but I have a new error while running the Advance Sweep.vi in one of the example drivers:
for suppose if I give the range of voltage from 1 to 5V, for some 10 or 20 points.,
but the program is terminating in the middle itself, after executing few points and showing the error code..
Error code: 5042 - cannot perform requested action while overlapped operation is in progress.
This come out in both the Keithley LCD and in labview..
01-15-2014 11:08 AM
I've seen this error when you are trying to change parameters of the Keithley while a sweep is in progress (writing a command to change/set the buffer size for instance). If a measurement sweep isn't finished and you send commands to change a setting you'll get an error.
Run the labview code with "highlight excecution" option selected, which will significantly slow down the code. If the error goes away, then it means your commands are being sent too quickly. You could also probe the various write commands and see if one of them excecutes as you get the error.
01-15-2014 11:11 AM
Can i have the Sweep voltage and current Measurement file for finding the Voltage VS Current graph
01-20-2014 08:54 AM
When trouble shooting i have some error in the messgae file i have attached that file in this message.Let me know what i have to do in order to solve that error.
01-20-2014 09:24 AM
01-20-2014 09:24 AM
I am getting the follwoing error which i run the file
Error 0 occured at GPIB write in KE2602A/Limit.Vi
Possible Resons
LabVIEW:Error connceting to GPIB driver or device
VISA:(Hex 0x0) operation completed successfully
01-22-2023 03:29 AM
I need help for this program. Could somebody assist me.. Please... I request
01-22-2023 04:04 AM
Hi Py,
What do you request?
Which kind of help/assist do you need?
What have you tried?
Where are you stuck?
Is it still the same problem as 9 years ago?
