I am using labview, call ViSa READ thread, with a total death appears
I am using labview, call ViSa READ thread, with a total death appears,  Information display (library loaded) in the dynamic library calls a user-defined dynamic library, whether the user is enabled in the user program of the dynamic libraries, and call the procedure was not introduced to close the dynamic library, which led to system calls, the pointer error ?
(2,393 Views)
I'm sorry, but your question cannot be understood. It seems that English is not your first language. Did you use a translation program to post it in English? If so, it seems to have not worked out so well. Perhaps it might be better if you posted your question in your native language. It's possible that someone who speaks the same language will be able to answer.
(2,382 Views)
