I have a problem creating EXE file
I have a problem creating EXE file in LabView. After running EXE file, LabView framework is always visible.
How can I create EXE file that only my window will be visible?
Message 1 of 12
(3,458 Views)
What do you mean by LabVIEW Frame work? (your front pannel Smiley Tongue?)
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 2 of 12
(3,453 Views)
I think he needs to post this in Measurement Studio for .NET languages board.
Message Edited by Mathan on 08-14-2009 03:38 AM
Message 3 of 12
(3,447 Views)
Hi tar81,
Do you mean the labview icon after creating exe. You can choose your own icon while creating exe. But is that what you mean?
Message 4 of 12
(3,428 Views)
Tar81 wrote:
After running EXE file, LabView framework is always visible. How can I create EXE file that only my window will be visible?
I think he is telling about the Run button in the window. Unless otherwise he get back with more details we can still guess....
Message 5 of 12
(3,414 Views)
Thanks for replies, I already solved the problem. But now I have another problem. I have a button. By pressing this button SubVI shall be opened. But this SubVI doesn't work until I run again the program (see attached picture). How can I do that the SubVI runned automatically when opens?
Message 6 of 12
(3,396 Views)
I cannot make much out of your attached picture. But you can putthe subvi inside a while loop for repeatedly calling the sub vi
Message 7 of 12
(3,383 Views)
if u can post the SubVI, u will get a solution quickly.......
There may be some problem with VI properties.....try to play with them and see what happens..........
Anil Punnam
CLD
LV 2012, TestStand 4.2..........
Message 8 of 12
(3,361 Views)
I attach an example of VI and SubVI. I call a SubVI, using a case structure, maybe it's a wrong solution. I need that when I press the button and the SubVI opens, it opened in a running mode. In this case it doesn't work until I press on Run (as it is shown in the picture I attached earlier). I tried to play with VI properties, but didn't find the answer.
Message 9 of 12
(3,326 Views)
You need to keep your programme in the while loop to poll the button is pressed?
Try the attached VI.
Message Edited by Baji on 08-17-2009 04:00 PM
Balaji PK (CLA)
Message 10 of 12
(3,304 Views)
