01-18-2011 02:20 AM
I'm working on DC Motor control using DAQ. There is sufficient voltage output from DAQ but not current. What should i do so as to drive the motor. Could you suggest me appropriate driver IC using which this problem can be solved.
Saravanan.T
01-18-2011 02:25 AM
Hello ,Saravanan.T
What kind of controll board are you using for driving the motor?
01-18-2011 09:55 AM
You really should use a DC motor controller to control a DC motor, look at the 754410 IC for a good example. You should be able to interface these to most DAQ devices.
Alan
