02-29-2024 08:41 AM
Hi, I am new to LabVIEW. And I am trying to control our Golander pump through LabVIEW. I wrote the following program in LabVIEW but the pump doesn't do anything. Can someone help me check the code?
02-29-2024 01:33 PM
Hi qsua
Here are a few things you can check:
I assume you're communicating with RS-485,
- check the serial port configuration
- try to read data first from the Modbus device to test that the communication is going through from the input registers (for ex 1023 product information)
- don't use loop while, just use one single strip : serial configuration, write, wait a few milisseconds( you need to try a number you need to wait for hthe instrument to respond) then read it.
- then try to write data into the register you need. Sometimes to write one command you may need to send multiple messages to the instrument obey you.
RKo
02-29-2024 02:38 PM
Hi Rko,
Thank you for your reply. I am communicating with RS-485.
- By test through the input registers do you mean the following? I have attached figures and the vi for you to check.
- I have removed the while loop but still did not let the pump run.
- I am not sure if the processes I am using is the right ones to use.
