07-10-2007 07:34 AM
Vincent Gathmann
MIS/IT Director
Pictorial Offset Corporation
111 Amor Avenue
Carlstadt, NJ 07072
(201) 935-7101 x429
vgathmann@pictorialoffset.com
07-10-2007 08:28 AM
I'm assuming that this is a proprietary format, so we can't really help you.
I suggest one of two things:
Either of these will allow you to write a converter.
If you don't have them, you could try the following trick - if the executable was written in a version of LV new enough to enable VI server connections, you can try opening a connection to it and calling the reader in your own VI to load the data. Once you have the data, you can resave it.
If this doesn't help, can you upload a sample file and tell us which version the original program was built in?
07-10-2007 08:46 AM
Thank you for your reply. The version of Labview that wrote the .HST files is Labview 7.1. We have a license for the application, but somebody missplaced the software disks (and license key) and we cannot locate it. The PC that had the application on it was repurposed. We have the original VI files that ran on the computer -- but missing the software to reinstall -- the VI files do no good. I will attach a sample file if you think this will help determine the format. Thanks again for your time.
Vincent Gathmann
MIS/IT Director
111 Amor Avenue
Carlstadt, NJ 07072
(201) 935-7101 x429
07-10-2007 08:48 AM
07-10-2007 09:02 AM - edited 07-10-2007 09:02 AM
Message Edited by GerdW on 07-10-2007 04:05 PM
07-10-2007 09:24 AM
Dennis,
I'm reluctant to post the VI files for legal reasons. I don't want to infringe on the rights of the author of the code. I've been trying to contact him for help, but I haven't located him. I don't want him to find me by way of his attorney. There is a 'toolkit' with a code in a folder called 'History Utilities". I just don't know how to read the code to determine what happens to write the files out in the format. I'd be willing to send you the toolkit portion if it would help, but I don't want to post to the board. Thanks again for your help.
Vincent Gathmann
MIS/IT Director
111 Amor Avenue
Carlstadt, NJ 07072
(201) 935-7101 x429
07-10-2007 09:29 AM
GerdW,
Thanks for your response. I looked at the file with a hex editor and concluded that the records are in 32 byte lengths, as you stated. I will take your infornation and try to chart them out, as you suggested. I cannot imagine where i get header information for this data, however. I'm only going to be able to guess what the values mean. We are going to look for some historical printouts to see if the headers are evident. Again, thanks for you help.
Vincent Gathmann
MIS/IT Director
111 Amor Avenue
Carlstadt, NJ 07072
(201) 935-7101 x429
07-10-2007 09:40 AM
It seems to me that you do not have any experience with LV yourself. I assume the history utilities folder includes a VI for reading the data from the file.
Basically, all you need is that VI, because if it will load the data into a format you can use, you can then easily convert the data to a 2D string array and save it as a CSV file. I would personally doubt the original author would object if you upload it, but it really isn't my place to tell. If you have an available version of LV installed anywhere, I suggest you find the VI which reads the file, open it and try to understand how it works. If you want to see examples of working with files, have a look at the example finder (Help>>Find Examples).
07-10-2007 09:58 AM
You are correct. I have no experience in Labview. I am an experienced utility programmer in C, so I understand file I/O -- thus my desire to get the file format.
I will compress the 'history' portion of the toolkit and upload it. Perhaps that will give you enough information to give me an idea of how those programs write out the data. I don't have enough time to learn LV to figure out how to comprehend how the toolkit produces it's output. Thank you for your help.
07-10-2007 10:16 AM
