I want to export result in my xml format
In my vi when i press enter button serial number and gtin number is exported in xml, i want to export my result in the below xml format (pls see attached for xml format)
(2,000 Views)
So there are numerous options for creating XML-style strings in LabVIEW.
Two such options are the built-in Flatten to XML, and the JKI XML Toolkit.
These, combined with various Bundle by Name nodes and an appropriate cluster, can probably produce the necessary string for you.
Here's an example using the JKI Toolkit:
Note the labels are used for the tags.
GCentral
(1,960 Views)
I find this example
can you please tell me how can i edit this vi to so that i can edit this to achieve my result
(1,940 Views)
